Super Jolly Stall
  • Yelta
    Originally posted by DesigningByCoffee View Post
    I'd be considering a greater issue at hand if an commercial quality SJ jams with more than 20g coffee in the hopper. This could win the battle - but might not win the war?
    I suspect your right Matt, with a 350 watt motor it should take a lot more than a hand full of beans to stall it.
    Its a good grinder, get it repaired before you burn the motor out.
    Given these things weigh about 14kg it must be a major pita turning it upside down and shaking it at the end of day.
  • javatime
    tip the grinder forward and grind. I do it when my grinder stalls sometimes and it seems to get it to start again without adjusting the grind settings.
  • flynnaus
    Originally posted by Bames View Post
    Seems to only happen when I invert the grinder to empty excess beans out.
    Maybe I'll stop doing that
    Sounds like the sensible thing. Inverting it might throw the motor out of whack.
  • Bames
    If I remove as many beans as I can with a spoon, grind them all out so the chute is empty, leave the hopper half full etc it's fine. Had the big hopper on there the other day with a kilo doing coffees at a mates party - it was fine.
    Must be that inverting does something weird.
    It's possible that the units Start/Run Capacitor is shot.
    Might be worthwhile taking to a competent tech. and have it checked out...
  • DesigningByCoffee
  • Yelta
    Originally posted by Thundergod View Post
    Have you tried loading just enough beans for the two coffees?
    Then there'd be none left to jam the burrs.
    My thought exactly, cheap set of scales, problem solved.
  • Bames
    Thanks for the replies
    Flynn - no not making adjustments while the grinder is off, and yes I do remove the burr carrier and clean pretty regularly (once a month).
    Maybe i'll just try to seal as well as possible as Matt says and see how I go.
  • flynnaus
    Are you making grinder adjustments while the motor is turned off? This is a common cause of jams
    Have you ever cleaned your grinder?
  • DesigningByCoffee
    Hi Bames
    You must have arms like Hercules!
    Seems like a heap of effort - and I do wonder if the inverting might be jagging up your SJ somehow.
    Perhaps you could leave the beans in your hopper (this is what I do) cut a disc the size of the inside diameter of your honey jar to sit on top of the beans in the hopper, put you tamp on to of that to keep it sealed as well as possible, and see what happens over a few days? If it still happen, it could be burrs?
    Just my 2c
    Matt
  • Bames
    started a topic Super Jolly Stall
    Super Jolly Stall
    Hey all,
    I have experienced my Super Jolly stalling on occasion. My process each day:
    - Load about 150g of beans into my custom made small hopper (upside down, cut and cleaned old plastic honey jar)
    - Grind what I need to 2 coffees
    - Pick up the grinder, turn upside down to tip the unused coffee beans back into the bag. Usually ends up leaving roughly 8-10 beans next to the burrs that don't make it out.
    Then the next day when I re-load 150g into my little hopper, once every 3-4 days the grinder will stall when I turn it on. I need to then do roughly a 1/8th collar turn (equivalent to about 10 'notches') to get it to grind and then adjust back while grinding to my previous grind point.
    Could it be somewhat expected that it would stall using this process? As in the inverting to clear the hopper moves the beans / grinds in the chute and then when reloading the next day it compresses them and makes it stall? Or could my SJ be getting a bit tired?
    BTW it's a 2006 build
