My grinder clogged up and started to make some strange noises as if there was a small pebble stuck in it, so I pulled the burr apart and cleaned it as I would normally. Upon doing this I found a small felt washer at the very bottom of the burr which had disintergrated. This is not a part which is listed on the breville web site and I was wondering if it can be replaced. As I cannot use the grinder without it.
breville smart grinder
Hi biss,
do you mean the upper burr (easily removed with the bucket - like handle) or the lower conical burr? If the lower burr, then metal shims are available for free via the enquiry form on the breville website. If the upper, I would still email them as they tend to be pretty rapid and helpful with responses.
sam
Here's the link to the SG thread. I can't find the pages where it talks about the felt washer but from memory everything works OK when you put it all back together after cleaning it all out. A great resource for all things SG otherwise too.
http://coffeesnobs.com.au/grinders/2...rinder-25.html
