Hello- has anyone had any success with slowing a grinder down? The Mazzer Major for example goes through a reasonable amount of coffee when dialling it in, and it would be nice to be able to slow the speed down for that dialling in process. I was think perhaps a dimmer switch or similar which reduced the current, but don't want to have to open the machine up, nor damage it in any way. Has anyone come across some sort of device that you plug into the wall outlet, which you then plug the grinder into, which can reduce the current. Any other ideas welcome.
Slowing a Grinder Down
Originally posted by Talk_Coffee View PostHmm....I can't see what the issue is? It's not about how fast you get a dose worth of grinds rather the volume and grind size. Use the switch and turn the grinder off once you have sufficient to test the grind.
I have a Mazzer Mini, only ever had to "dial it in once" when I first bought it, even then it was a simple process.
Now I know the grinder I'm usually pretty well spot on, even with new batches of beans, only very minor adjustments are needed.
I suspect attempting to slow the motor by reducing voltage may have a detrimental affect, might even cause it to fail.
Interesting question, and my understanding of running appliances on a lower voltage than they should get, is that the windings can run hotter than they should, resulting in possibility of the motor burning out. But I'm not an electrical engineer and there are others in here well qualified to reply to this. Guys?
Another point of view is that the Major is a volume cafe grinder and by its very nature, it grinds coffee quickly because it is designed to do so. I don't see any advantage in having one in the home and this is precisely one of the "problems" that may manifest for an individual using it in a small volume situation and for whom wastage is important.
Changing over to a smaller but similar design grinder will help resolve the issue, very probably with no discernible loss in quality in the cup. By this I mean, models such as the Mazzer Mini or Macap M4 or M2, Eureka Mignon, Compak K3, or any other grinder using cafe type flat grinding burrs down to 58 or 50 mm diameter.
Just some lateral thoughts, in case simply developing an acceptance of how the Major is, is not an option.
Originally posted by TOK View PostInteresting question, and my understanding of running appliances on a lower voltage than they should get, is that the windings can run hotter than they should, resulting in possibility of the motor burning out. But I'm not an electrical engineer and there are others in here well qualified to reply to this. Guys?
Reduced voltage is NOT the way to reduce speed on an AC Induction Motor. Specially designed Variable Frequency Drives are what is required and even then, you very much need to know what you are doing...
Frequency affects the motor RPM.
In Australia 50Hz gives you 2880 RPM on a 2 pole, 1440 RPM on a 4 pole.
50 Hz (Frequency in a second) multiplied by 60 (seconds in a minute) gives you 3000 RPM.
The reason for the slightly slower speed is due to motor inefficiencies.
I'm sure an electrical engineer could explain it in a lot more detail, that's some info given to me
by a motor rewinder I used for several years.
