I just picked this baby up this morning and had it dialed in after two attempts. Chris@talk coffee advised I turn the micrometric adjuster back about 10 times as its set too fine out of the box. 9 times would have done it. It appears that one full turn of that adjuster changes the pour time by about 5 seconds. I then attacked the timing feature. I read that it doses at about 2gms a second and I wanted 16gms. So I tried 7.5, 8.0 and 8.5sec and 8.5 did it. The time can be adjusted in 5 / 100ths. So I could get 8.45 or 8.55 seconds if I really wanted to fine tune. Repeated and weighed 3 times and all were exactly 16gms and more importantly great shots with a great taste. Clumping is there but they are soft and break easily when the group handle is shaken. I was told that once the burrs settle down this clumping becomes even more insignificant. Clumping and grind retention as mentioned many times on USA sites and this site are non issues. It is an accurate, consistent and sophisticated grinder and I'm delighted with my purchase. I really don't understand why this grinder has had such a bad rap.
Chris often gets thanked for his service but he really does deserve it. He clearly explained why it was better than its biggest rival, the Mazzer mini e and gave valuable advice on how to set it up when I got it home. While my old grinder (K3T) was very good this really feels like a step up in quality. As big Kev used to say - I'm excited.
I can't recommend this highly enough.
Thanks again Chris.
Thanks again Chris.
