Removing threaded screws out of Rocky help needed
  • #16
    Originally posted by TampIt View Post
    Impact screwdriver with a correctly sized flat head tip will then remove it.
    Agree 100%...
    If you are doing all this to rotating burr, then you will most likely have to replace the bearings as any impact applied like this, will almost certainly damage the bearing surfaces to the point where early bearing failure is pretty well guaranteed. Thankfully, replacement bearings are not expensive and well worth the effort to install. If you are unable to locate OEM bearings, take the old ones down to a Bearing Centre (or similar) near you and they will be able to fix you up...
