Looks like youd get a lot of coffee stuck in between the body of the grinder and the PF fork.
This was taken off an American site..so Id assume the voltage to be Aussie specs.
* High-quality polished stainless steel body
* Adjustable gauging and grinding
* Motor V110 60 Hz Watt 250 with built in thermal protection
* Single-phase 1340 revolutions
* Flat burrs size: 50mm diameter
* Bean hopper: 250 grams
* Net weight: 12 pounds (approximate based on manufacturer spec)
* Measurements: 13.5" H x 5.9" W x 9.95" D (approximate based on manufacturer spec)
Main things are it has 50mm flat burrs, not sure what replacement burrs you can put on these. It is 8mm smaller than the Mazzer mini (which turns around 300RPM faster) and the mazzer mini is SLOW.
