Well the story goes like this:
Someone I know well has a Baratza Preciso grinder. For those that are unfamiliar with this model, it has a push button on the front to pulse the grinder and a mechanical timer on the side to do a timed grind. The mechanical timer is very imprecise, and really only enables you to make sure the grinder turns off if you have to go to the loo in a hurry (or whatever).
So, the owner of the device had been using it in a single dose fashion - just dumping a PF-full of beans in the top and grinding them all. He discovered that the dose was varying too much, so he said to himself, "why don't I make a timer module?" A few minutes later he'd ordered a $7 digital timer incl delivery from China, and he spent the next little while planning how the timer would work.
A couple of hours later I felt like a coffee, err.. I mean HE felt like one. He went to the grinder, and noticed for the first time that on the wall immediately above the grinder is a clock with a sweep second hand. It had only been there for five years or so. Now, the incredibly crafty mind of the owner suddenly realised that it would be fairly easy to observe the aforementiond sweep second hand and push the grinder button for the required time. Doh! Accuracies within 1 second should be achievable, and over the 13 secs required for a double PF any variation should be small.
So now the owner is happy, having got the result without having to build a timer. Except for the fact that a timer will arrive from China in a couple of weeks...
KISS.
Gonzo
KISS.
Gonzo
