The short of the story is I was cleaning the grinder at the workshop (K6 Diamond Doser) had it all apart and clean. Then someone dropped the clear plastic doser chamber and cracked it. Where can I get a new one any help appreciated. I did a quick search on here and came up with nothing.
Arhhh broken Diamond K6
Ascaso. Check if part number K...30 will suit. If so, it's well less than 10€ direct from them if you have an account.
It doesn't specifically list K6 Diamond in the cross reference, but lists it as the standard dispenser and for a number of models including a few K6 models.
If you don't have an account with them then I'm not sure which local (Aus?) parts retailers do, but I assume that at least a few would have accounts and could possibly order for you. Perhaps try coffeeparts and ask if they can order?
Not sure if you're in a hurry for it, but if someone orders it through Ascaso it will have to come out of Spain so freight will likely cost more than the item unless it's part of a bigger order.
