I've figured the ups and downs of the Skerton and would like to share my findings....
(Durability)
Not so good, the glass bottom receptacle is fragile... but the hopper can withstand impact.
The burrs are made of ceramic and thus its very durable.....
(Grind)
The capacity is great, but the grind gets more inconsistent, the coarser you set it to... The fact that it isnt stepless is a pain.... and if you want to grind coarse you'd better get the OE lower bearing..... Otherwise you should grind as fine as possible...
The mini mill is adjusted from the bottom and that puts the Skerton to shame for not adjusting convieniently.....
(Portability)
The grinder does feel quite heavy but it isnt as heavy as a LIDO2 and it's physical size dwarfs the mini mill.... and the fact that the mini mill has a plastic receptacle.. makes me feel like im gonna break my grinder during travel..... (as mentioned in the durability section)
Hope you like my review....
(Durability)
(Grind)
(Portability)
