Re" "...what about the cunhill?..."
The Tranquilo is a great little grinder but one of its foibles IS the mess.
It is a far superior grinder to the Challenge and probably on par with the rocky depending on what differences between them may be important to you as an individual.
For those that are not familier it comes in 2 versions,
a) the "timed dose" version (no regular volumetric doser) and the
b) doser (regular volumetric) version.
The dosers fitted to these grinders are in the *bottom end* of the range of commercial grinders. They are streets ahead of the dosers commonly fitted to domestic grinders, but way behind doser units as fitted to good quality Italian full commercial grinders.
Suggest you weigh up the reasons why you want to change, and compare what you have with what you may end up with. From my own experience and for use at home, I dont see any advantage in trading from Rocky to a Tranquilo. All you will end up with is a slightly different method of delivery, & similar or more messiness....says I, the king of coffee mess
!!!!!!!!!!!Regardz,
FC.
