What brushes do you use for your grinder?
  • #16
    Re: What brushes do you use for your grinder?
    Originally posted by tempestv8 link=1176982088/0#14 date=1177033296
    You may not know it, but the tools that my Land Rover dealer uses are top shelf Snapon brand tools. Try $80 for single spanner, rather than $50 for an entire set that you can buy in Bunnings.
    I dont think Holden dealers buy tools from Bunnings either. And my Toyota and VW also requires 98 octane.... which comes from the same refineries as does the fuel for the Ferrari.
    Coming back to the topic of coffee, I guess thats why there is a market for some cool coffee tools. I see that Rancilio have a coffee tamp for $85, and Greg makes some beautiful tamps. So if there is a desire to enjoy making an espresso using well crafted, beautiful tools like a Pullman tamp, I would imagine that it would only be natural to ask if theres a good quality brush out there.
    I used my wifes baking brush to clean out the grind from my coffee area and the bristles came off everywhere, so Id imagine it wont be any good for cleaning out a grinder. So Im merely looking for information for where to find a well made brush thats suitable for a grinder.
    The main reason we use tampers (which Ill agree look great) is to replace tampers that dont work properly.... the standard tampers are the wrong size, uncomfortable to use, often made of poor quality plastic so you cant exert the correct pressure without them deforming etc.... so a replacement quality tamper is sought to enable the correct functionality.... and Gregs are great for that... plus they do look good sitting on the bench!
    Clearly your baking brush also isnt fit for the purpose - it shouldnt lose bristles..... But the $2 ones dont lose bristles and are fairly stiff - so they work really well.... and as was said above - you would be hard pressed to tell them from a $20 brush bought from a speciality store...
    I guess there is a market for quality tools to enhance functionality (like Gregs tampers) but not so much for things like grinder brushes as most of us find that the "cheap and cheerful" ones do a perfect job. If someone made a quality "purpose built" grinder brush the demand would probably be quite small..... a bit like the demand for a small sized low speed conical grinder (a mini Robur) because the cost would out way the benefits in most peoples view.
    • #17
      Hi JavaB,
      I agree, there doesnt seem to be much of a demand for a quality "purpose built" grinder cleaning brush. :-[
      Im sure that if theres a superior value proposition for buying one, then it will be possible to create a market for it.
      Ive used cheapo cleaning brushes (for house cleaning), and then found an expensive one which worked so well, I never looked back. Theres simply just much less effort and far better results with quality tools.
      I will endeavour to find a great brush for sweeping out the grinder and report back to the forum, if I do find one.
      Hopefully Ill have an update for you all!
      Lawrance
      • #18
        Originally posted by tempestv8 link=1176982088/0#8 date=1177028155
        Having a basic paint brush from a hardware store next to a magnificient Mazzer or ECM Best or Macap really doesnt do it much justice. :-[
        Keep all my coffee tools in a cupboard below the bench where the hardware sits, no-one need ever know :
        • #19
          I have found a variety of brushes, and since it is our site sponsor, I think I can post the link here:
          http://www.coffeeparts.com/accessories/brushes.html
          Cheers all!
          Theres only the one brush for a grinder but I think that the group head brush would be quite effective at removing the grinds from
          the chute...
          • #20
            Would you be using the group head brush to also do the group head?
            Because then you would have the possibility of transferring moisture to the chute of the grinder.
            I just use a pastry brush with a wooden handle. $2.50 I think. Doesnt shed bristles, small enough to poke into the chute, large enough to also use in the doser.
            And, like Mal, all my tools (except the tamper) are in a drawer out of sight.
            • #21
              When you get right down to it, I think too much is made of supposed difficulties with cleaning your grinder and the frequency that cleaning should take place.
              Most grinders allow for the simple removal of the top burr carrier assembly with hopper, etc. Once this is removed, its extremely simple to clean the static burr and with the use of the end of a vacuum cleaner hose and any kind of stiff bristle brush, toothpick as someone else has mentioned, it probably takes all of two minutes to clean out the grinding chamber and rotary burr. I dont have a doser grinder but I imagine a vacuum and a bristle brush would make pretty short work of that too.
              Dont need to make this small chore seem any harder or more arduous than it really is. Regarding frequency of cleaning? I do my Rocky about once a fortnight after the weekly house vacuuming is completed and before the vacuum is put away in the cupboard. In truth, the most difficult part of the whole exercise is putting the vacuum away when the job is done. Think there is a certain amount of mountain building from molehills going on here :-?,
              • #22
                Agreed Mal- Its the vac every time for my grinder ....I often use it as a place to let freshly roasted stuff de-gas as well  :-[ 8-)
                • #23
                  I have a set of mini attachments for my vac which I use to give the grinde an extra clean with occasionally.
                  As for the group brush from Coffee Parts, It looks like the one I have and the bristles are too stiff and too short for my grinder.
                  tempestv8, really with the many variances between so many different grinders, I reckon it wough be nigh on impossible to come up with anything better than whats already out there.
                  All you have to do is find one that suits your needs.
                  • #24
                    You de-gas your roasted beans in a vacuum cleaner? :P ;D ;D ;D
                    • #25
                      wouldnt expect car dealer service departments to buy their tool sets at Bunnings --- but I did. ;D ;D
                      In them thar days it was called McEwens, and the range was limited somewhat. Good thing, too. Because there were no cheap Chinese imports, so you couldnt go far wrong.
                      I have no regrets in having spent lots of cash on Sidchrome spanners, sockets, wrenches. They have a lifetime warranty, and only one 19mm socket has broken since. :-/
                      Off topic? --------------no! Ive been using those tools on my coffee machine!
                      (Along with a small kitchen pastry brush for the grinder)
                      -Robusto
                      • #26
                        I just use a soft bristle brush in combination with a garden variety toothbrush. Seems to do the job quite well. Like others they sit in the cupboard. If I left them beside or near the grinder, the cat would steal them and the dogs would chew them up.
