Single Dose Hopper for Macap M2M - a quick hack
  • #16
    Can't a single dose simply be achieved by tipping the measured beans straight into the standard hopper, and then grinding them all out, and sweep / pick / snort / blow / jiggle / vibrate / vacuum or levitate all the grounds out of the chute? That's what I used to do with my M4 (bar the levitation)…
    The main reason for a micro hopper is to allow you to keep some weight on top of a much smaller amount of beans to 'fool' the grinder into behaving like it's got a full hopper, giving a more even grinding (my micro hopper holds about 100g - with about 75g retention in the burr set ).
    But in reality you're never going to make the most of this micro-hopper technique 'single dosing' with an exact measure of beans anyway - half are into the burr cavity even before you start, and the weight/tamp will stop applying any pressure long before the beans run dry! You'll always need more than a 'single dose' for this method to work…
    So maybe measure an extra 2g, run it all through, sweep out as much as you can, and enjoy your brew!
    Cheers Matt
    Just a slightly amusing story - I know a bloke who used to strip down his grinder to the burrs every time he made a coffee - that's a guaranteed way to avoid retention and get 18g in / 18g out!
    • #17
      Originally posted by DesigningByCoffee View Post
      Can't a single dose simply be achieved by tipping the measured beans straight into the standard hopper, ....
      But in reality you're never going to make the most of this micro-hopper technique 'single dosing' with an exact measure of beans anyway - half are into the burr cavity even before you start, and the weight/tamp will stop applying any pressure long before the beans run dry! You'll always need more than a 'single dose' for this method to work…!
      Hmmm ?... Odd then, that so many people have been using the weighed dose of beans so effectively for many years !..... Must be down to the ability of the individual user to figure out the optimum technique.!
      • #18
        Sorry - might have been a bit obtuse - that's was my point
        I've used the weighed / measured dose method too straight into the hopper/throat of my M4 - it works very effectively!
        But that uses a different technique to the usual 'weighted micro-hopper' which Mal and myself use - where you use more beans and a weight / tamp on top - but just grind what you need. But is generally not a 'single dose' method (ie clean grinder in - beans - clean grinder out) method as defined
