This is how I've been brewing my black coffee with Aeropress and Breville BCG800 Smart Grinder for the past 2 years:
I've been using the Dibella Nero Blend Coffee Beans because I've come to like the taste of dark roast because of their consistency.
I'm pretty happy with the current taste of black coffee with the way I'm brewing right now, but I'm not sure if I'm brewing the best black coffee possible. So I've tried a different approach today by brewing for 1 minute with the finest grind setting, but when I did that, the coffee had too much body and it didn't taste nice.
So I'm wondering, what grind setting on Breville BCG800 Smart Grinder do you guys use to make 1 cup of black coffee with Aeropress? And how long do you brew for?
- Grind 1 Aeropress Scoop worth of Coffee beans at Level 5 Percolator mode in Breville BCG800 Smart Grinder
- Pour the grinded coffee into the inverted Aeropress
- Boil to 93 degrees on BonaVita variable temperature Gooseneck kettle
- Pour the boiling water all the way to the top in the inverted Aeropress
- Brew for 2 minutes
- Put on the Able Disk Fine Filter
- Plunge
