Hi Guys,
I noticed that when my Rocky was turned down to below 5 on the dial there was a noise that appeared to be the burrs catching. They are not grinding on each other but seem to catch each time the motor turns. This produces a knocking noise and gets worse the finer the grind.
I took the hopper and the top burr off but when re-assembled there was no improvement.
After some research on the net Ive seen that a number of others have experienced the same problem with their Rockys.
Just wondering if anyone has had this problem and if so, is there a fix you can perform? Im expecting to have to take it to Cerebro to be checked out but if there is an easier way around it Id love to know.
