Rancilio MD50 project
  • #16
    Regarding a suitable grease mate, head off to Supercheap Autos or similar and grab a small tube of Lithium Grease. Use very sparingly on the wearing surfaces after which it will last a very long time...
    • #17
      Originally posted by alsd View Post
      [ATTACH=CONFIG]9707[/ATTACH]
      Bottom of the doser. The offending bastard nuts can be seen. So too can the doser mechanism. My previous question re lube for this and these microswitches releases to this mechanism.
      Yep , I'm struggling with them as well..
      • #18
        being a painter, you would know how to do this properly! How would you go about it? I'm thinking of bead blasting the old paint off, cleaning up with acetone then I'm a bit stuck as to the paint to use and the prep. Will you be doing a primer and then colour and a clear? What kind of paint? I have no booth or even a workshop so it'll be off to a shop to get it blasted then painting in the backyard for me. I fear I'm at the mercy of cans. Any suggestions?
        I would suggest to save your money and don't bother blasting it.
        If mine was as good as yours, I would just give it a rub with a fine grid sanding paper and recoat it with paint.
        The original paint is still good, no need to remove it with blasting, all you need to do is create scratches so the new paint will stick.
        There also wont be a need for primer, as the old paint will take over that function.
        Then just buy a spraycan of you color choice, and have fun
        If you want a glossy finish, or if you feel you want to paint 2k paint. (paint with hardener)
        Go to your local autobarn or supercheapautos and they can help you.
        It is possible to get 2k paint from a spraycan.
        I may be a painter, but am currently without workshop.
        So I am just going to use cans.
        Which is perfectly fine for the job.
        In my case , the paint is severely chipped and peeling off. (I'm trying to upload a picture)
        I need the level out those paint edges for it to become smooth again, so I might need a coarser grid sanding paper.
        Then I will apply some primer to see it it is all leveled out , and to fill the scratches created by the coarser sanding paper.
        Then I wil sand it again with a finer grid , ready to be coated.
        I am just planning of getting matt black , as that's the original color.
        • #19
          Righto,
          All done as of this afternoon HOWEVER, I stopped at just cleaning it up, new burrs and a thorough reassembly (only one washer left over at the end, feeling quite proud of that)
          Toom your advice Dam and didn't blast, hell I didn't even paint it. Didn't polish the plastic etc. I kinda like the rough and ugly nature of it now
          After assembly this arvo I've only had time to zero the grind and then try a few test grinds. I'll be going for the right grind in the morning with brekky.
          The only real trouble i had was:
          1. Those bloody 10mm nuts on the bottom of the doser. Ended up taking Mals advice and heading to bunnings and getting a set of tube spinners that I'll probably never use again but it got the job done. It was still tight even using these so yeah, enjoy.
          2. The wiring. When I unplugged the relay block, I labelled that wiring in a way that I thought would be good for reassembling in the correct connections. I used a black texter to label the wires and their connectors, I didn't realise that my texter rubbed off very easily (I thought it was a permanent one. It wasn't). Took a bit of guess work, looking at wiring diagrams and trial and error but I think I have it right now. It works anyway.....
          3. When reassembling, I accidentally had a wire between the stainless body and the base plate, this ended up in shorting out the unit after I screwed the body together and then the wire shorted on the stainless.... Be careful of wires getting stuck!
          apart from that it was pretty easy although I did chicken out and not really desconnect the wiring and fully remove the motor etc. I was able to clean it up well and I'm happy with where it's at. More importantly, the internals and all bits that touch coffee or store coffee were fully cleaned and restored to as new condition so there should be no stale coffee ruining my fresh cups in the morning!
          anyone needs some help I'd be happy to provide any advice from my experience.
          Al.
          • #20
            Day one of use report for those that are interested.
            good machine, naturally, no problems with power, no bean is any kind of match for this bohemoth, grinding away with ease.
            after reassembling I've heard a scraping sound when the burr assembly rotates. I've narrowed it down to the burr assembly touching the base of the grind chamber when it rotates. There was a wear mark in the chamber but I'm not too concerned, in fact I reckon it'll be good as it'll provide a place for the ground stuff to be swept up and sent away.
            getting the grind right will take a kilo or two I think. Trial and error, to be expected with any newbie starting to grind their own I expect.
            Regarding the auto function, not really too fussed with it. I just switch on, chuck some beans in the hopper, click the start switch and grind away till empty, then switch off. No big deal.
            Biggest irrit is the fact that so much coffee stays in the chute before the doser meaning that I'll need to get a "device" of some description (fancy description for a bent coat hanger) and scrape out the chute to avoid stale coffee staying in the chute and then ruining my first shot of the day.
            once the coffee makes it out of the chute into the doser, it seems easy enough to empty to doser and get into the portafilter however there is a fair bit left over in the doser and it feels like a lot of wasteage.
            So, all in all, for absolute overkill for a house machine that makes about 4-6 coffees a day, I'm pretty happy. Considering my constrained budget and he fact that all up I think I'm in it for about 180, I have a grinder that's going to last as long as I am alive I think and it can handle anything I throw at it.
            id be happy to hear any stories that make this a bit more efficient to use from other MD40/50/80 users.
            The mrs hates it as she's not to pretty but I love it. It's like having a race car to get the milk from the shops
            • #21
              And when I say "she's not too pretty", clearly I meant the grinder, NOT the mrs..... Should she ever read this lol
