I highly recommend you take a look at the Compak K3 if you can stretch your budget a tad bit more. Haven't used or seen a Baratza in the flesh so can't comment on them. Not too many around and from what I know of only Five Senses sells them in Aus. I can personally vouch for the K3 tho, very solid build and also quite pretty
Pretty sure it has Mahlkonig Vario running gear under the body and I wouldn't touch one of them with a ten foot pole. Build quality is shocking.
I can vouch for the K3 also as I own one. Can pick them up from Jetblack Espresso for around $550.
Alternatively, another highly rated grinder is the Macap M4D. Talk Coffee sell these. I believe any of the Macap rage are good, the M2M might be more in your price range.
I also think Preciso might not be the best. But since you are already looking for it, those are the shops I found: commercial link removed per site posting policy or you can order it on commercial link removed per site posting policy.
Talk_coffee mentioned Breville smart grinder might be better... Um, actually if you are buying smart grinder, buy Breville smart grinder PRO (review). You can get it for 270 AUD on Breville website.
Reason: Commercial link(s) removed
Ok,now I`m undecided. Read a number of reviews on the Preciso and they seem to come up ok,some reviews preferred it to the Rocky which was what I was looking at to start with. So the Breville Smart grinder is it any good? I was staying away from the Breville/Sunbeam type grinders as I had a EM480 and was not that happy with it's grind performance, maybe they have improved. I`m using a Gino Rossi R45 grinder which I have had for a couple of years but it need to go, its just too big. `m using it with Brugnetti Simona Top.I`ll check out the K3 although it may be out of the price range.
I guess it depends on what you're willing to spend. The Preciso looks to be very similar to the Breville Smart Grinder. Considering you can usually pick up the Breville for around $200 it's probably the best buy at this point. I've got a Simona Top too that I'm currently using with a Sunbeam EM0480 that I've very carefully reconditioned and calibrated with excellent results. If you're going to spend $300-$400 I'd be buying a second hand Compak for sure as by all accounts it will outlast and outperform the plasticky offerings from Breville and Baratza at this level.
Thanks Leroy. I still have the EM0480 under the house somewhere maybe I should pull it out and give it a go then. Never ground with it for the Simona. It bought it for my EM6910 when I was using that.
I'd give the Sunbeam a go for sure. Get it working well then sell your RR45 to fund something really good like a Compak. If you do decide to resurrect your Sunbeam I'd pull it apart and give it a good clean then try grinding with it set in the middle of the scale. Work your way one way or another on the settings until it's at the right point for espresso. If you end up all the way to the left and it's still not grinding fine enough you're going to need to shim the lower burr. It's easy enough to do and shims are available from Ewing Electrical in Nowra who sell them on eBay (or I can send you a spare if you need it). Ewing Electrical also have a page on eBay that shows how to fit the shims.
My feelings are the same as Leroy. And as CT subtley tried to put it.
Your new grinder will eventuallybe compared to the Rr45 - a very good grinder ( commercial qlty)
All the grinders mentioned are infact a step backwards - never good thing in coffee appreciation land !
Note -I am not pushing the grinder I'm about to mention, it the experience.
Once I stepped up to a better grinder ( super jolly) my espresso experience lifted dramatically -
I could now quickly and easily match my beans / roast/ blend / grind / dose / tamp / basket at will.
And I could easily change any time I like.
In short the grinder IMHO is the centre of all the experiences of your coffee adventure.
Its obv your choice - I'm just passing on my experiences ( and unsaid are the frustrations of trying to get a grinder that doesn't match my
Machine and get a good quality of shot from it)
Gwet a grinder with same / similar or better grinding ability with a smaller footprint.
Long after price is forgotten quality will be remembered
G.L.
Going from a commercial grinder to a domestic appliance is a retrograde step and I wouldnt do it. There is an entirely different feel, and easier total grinder management in a commercial grinder...in essence, the "total experience". There is more to a grinder than delivery of grinds.
And in terms of the "size" of a grinder, take care that by far the biggest difference between an RR45 and a smaller domestic model will be in the HEIGHT, not so much in the footprint.
Suggest you dig out your EM0480 and see how you like using that in comparison to the RR45. That will be an easy (and free given you already have one) test to see f you can live with the consequence of moving backwards in order to gain a bit of extra space.
You could of course go to a macap M2M or a eureka Mignon which are tiny commercial grinders and have a similar total experience / feel to using larger commercial grinders. They will also last decades with little to no maintenance. However, to go there is still to spend money on a sideways step.
One suggestion: If your RR45 is an older version that doesnt require the genuine hopper in place to operate, try removing the hopper and feeding it through a temporary, smaller hopper arrangement. That wll make the grinder seem significantly smaller, and will certainly be more convenient if the grinder is sitting under an overhead cupboard. May as well explore your options before making up your mind.
Thanks everyone, some good advice given. The height is not the only issue with the RR45,its also a doser model,and as i`m the only one at home that drinks coffee it's just a pain. I never put much thought into it at the time just bought it on impulse. So yes maybe I still need a commercial grinder but something smaller. I`ll try the EM0480 over the weekend and see if i`m disappointed. Although LeroyC is happy with his grinding for his Simona Top.
Hi noidle22
I guess your "Mahlkonig Vario running gear under the body" must be talking about the first model Vario, which I have only seen "under the bonnet" in photos. The "gen2" is a Swiss made sealed module designed by Ditting. Literally a "plug and play" replacement if one is ever needed. My older gen2 has now done well over 150Kgs and the ceramic burrs are still unmarked* as is the insides. It is impossible to tell whether you are looking at my newer gen2 (about 10 Kgs of use) or older one unless you check out my "Texta markings" or find a serial number. Considering my "recently ex" SJ cannot even get 80Kgs before the burrs are shot (i.e. coffee goes to crap) and it never came close to either the coffee or build quality of my Varios it joined a group of 17 "mostly commercial starting with C M & R" grinders I sold off.
For home use the gen2 has two minor quirks/annoyances, neither of which affects the flavour in the cup. Both my gen2's have the rare gift of being small, quiet, unobtrusive & SWMBO inoffensive. An accurate timer (repeats are within 0.1g!), well over 50 real "within espresso range"settings, a very narrow particle spread and minimal grind retention adds to the charm. The gen2 is still the only electric home grinder I know of that can also go straight into my Ibrik when I feel like a (very) traditional Turkish coffee. My antique Turkish hand grinder is now "surplus to requirements" other than as an ornament. No static, no clumping, no mess on the bench* helps to make the gen2 the easiest grinder to live with at home that I know of - and since my first espresso encounter was 1970, that is a hell of a lot of grinders!
Of course, all the above would be completely irrelevant to me if they didn't also happen to produce the best quality of "in the cup" espresso / Turkish coffee of any home grinder I know - and not by a small margin. Very few commercial grinders come close to the in the cup experience. The commercial ones that do are well over $2000 - i.e. three times the price and they are not really suitable in a domestic kitchen for low intermittent home use anyway AFAIAC.
* My older gen2 did a few weeks in a busy cafe on two separate occasions. Used for decaf when their La Cimbali needed some TLC and did 20+Kgs a week there. No overheating or any other probs. Maintenance issue: the chamber needed a cleanout every 750g, which is a PITA in a cafe.
** It must be 12 months since I bought my first gen2, not a single ground outside the p/f yet. Initially I had no intention of buying a second gen2 until I tried to match the coffee quality with every site "out there" I could access - a mix of roasters, cafes and upmarket home setups. Half of them bought a Vario gen2...
Enjoy your cuppa
TampIt
PS: I probably wouldn't buy a Preciso for espresso use anyway as the Vario was a lot better in the cup. I am still looking for a really good home grinder for cold steep / drip etc (i.e. the coarser grinds) as the gen2 Vario is really fine tuned for the Turkish to espresso range. The perfect home grinder is still out there somewhere.
PPS: The Baratza is the parallel import from the US in lieu of the "rest of world's" Mahlkonig. I have posted that on CS several times yet the message is not getting through. Grand Central at Bibra Lake are among many that sell the Mahlkonig Vario in Australia (I bought mine from them).
