Profitec Pro T64
  • kofekitt
    Originally posted by Melbroaster View Post
    Have searched the interwebs - can't find any reviews or even videos other than the slow-mo. What do you think this would compare to in the Mazzer range in terms of grind quality?
    Ps. On the sides of the grinder are the 27 black dots in the profitec logo actually ventilation holes? If so, I would be concerned about the effect on internals from accidental liquid splashes over time from such an exposed area.
    Not holes, just cut-outs in the stainless panel, solid side panel behind that
  • BrissyBrew
    It looks like the ECM grinder new badge (sister is profetic's sister company after all), same count down time, bur diameter only difference besides the case is the instead of just exit chute it has a coffee hopper (sorry don't know the technical name for it) The motor is vented on the ECM grinders at the back, even the aluminium casting for the motor had fins to assist with motor heat dissipation.
    Look up the ECM 64 grinder has a couple youtube videos of the internals motor etc.
  • Melbroaster
  • JetBlack_Espresso
    Yes, the timer in the video has a decimal point which you may not have noticed due to the video quality. So it is displaying 2.X seconds and then 1.X seconds rather than 20 seconds plus. They've slowed the video by about 10x too so it's even more deceptive.
    charlie
  • Melbroaster
    Grrrrrr. Just noticed the decimal point on the grinder screen
  • Melbroaster
    Charlie the weird part is that the time that i was quoting was from the display on the front of the profitec grinder in the video. Any ideas?
  • JetBlack_Espresso
    I've got my demo T64 set to 6.7 seconds currently for an 18g VST pulling nice slow double ristrettos on our E61 equipped demo machines. The video you're referring to is in slow-mo! Not sure why'd they'd choose to show it in slow motion ... Nice effect but a little misleading if one of the main features of this new grinder is speed!!!
    charlie
  • Melbroaster
    Can you please clarify the grind time claim of 7 seconds. The video on the profitec fb site seems to show 25+ seconds to grind 1shot?
  • JetBlack_Espresso
    started a topic Profitec Pro T64
    Profitec Pro T64
    Profitec Pro T64
Name:	Profitec ProT64 med - front II.jpg
ID:	757494Click image for larger version
Name:	Profitec ProT64 med - seitlich.jpg
    Specification:
    • Simple programming of the timer for 1 or 2 portions via digital display (0.1 second increments)
    • Manual grinding function
    • Grinding time is about 7 seconds for a double espresso (18g)
    • Stepless adjustment of the grind
    • Quantity counter of the ground portions
    • Capacity of bean hopper 550 g
    • Stainless steel burrs, ø 64 mm
    • Vented body for better heat release of the motor
    • 430 h x 170 w x 250 d (mm)
    • 7.5kg net
    • 1400 rpm
    • 450W motor
    • 240V 50Hz
    First Australian stock has arrived - check with your local Profitec dealer.
