Specification:
First Australian stock has arrived - check with your local Profitec dealer.
- Simple programming of the timer for 1 or 2 portions via digital display (0.1 second increments)
- Manual grinding function
- Grinding time is about 7 seconds for a double espresso (18g)
- Stepless adjustment of the grind
- Quantity counter of the ground portions
- Capacity of bean hopper 550 g
- Stainless steel burrs, ø 64 mm
- Vented body for better heat release of the motor
- 430 h x 170 w x 250 d (mm)
- 7.5kg net
- 1400 rpm
- 450W motor
- 240V 50Hz
