EM480 - settings just changed!!
  • EM480 - settings just changed!!
    A few days ago a weird clunky noise came from the grinder.
    Then a few days later it seemed not too grind.
    it appeared to be blocked.
    It had been set on 4-5.
    I pulled it apart, cleaned and checked it, it has 2 shims.
    Put it back together, same issue, works but no beans getting ground.
    now I have reset it to 9-10, all is good again.
    the grind is as fine as it was when I had it set on 4-5.
    I used a naked P/F and VST baskets, so I can see what is happening easily.
    EM6910 coffee machine.
    Any comments
