Can't choose a new grinder <$500
  • kbc
    Go for the Macap m2m. I have owned a K3 and the grind retention was a deal breaker for me.
    Good luck
  • anon
    Sorry to hijack, but thought best to continue on a thread that is essentially the same to my dilemma. I have an EM7000 and EM0490 grinder. Of late the grinder is becoming frustrating to use, no longer is dialing it once enough, I'm chasing around the same 3 settings every few days to get it back on point.
    I borrowed a Baratza Precisio once and the difference was astounding. I had the chance to borrow it again recently and again was blown away by the difference. The Precisio (and CS politics aside) is an option but with the dollar its not priced not too far off the M2M and K3. How would these compare in grind quality to the M2M and K3? I would imagine build quality wouldn't be much of a comparison. Typically have milky coffees but also LBs and espressos if the mood is right. Also have an aeropress, but not sure it would get much use with it.
  • DaveD
    The K3 is a great grinder, which will outlast the Sunbeam. It will be good enough to be matched with any prosumer machine after that.
  • ArnhemR
    Would the K3 be a good grinder for pairing with a higher end Sunbeam coffee machine? (dont ask, its not for me!) They have borrowed my spare K10 until they find a new grinder, they prefer the 'serious' grinder look.
  • Perthsnob
    Cheers Chris
  • Chrisj1984
    Hi there i love my k3 push. Simple. And great consitency. Upgraded from a brevillle smart grinder and difference is huge. Much nicer grinder to rocky also.
    Just my 2c worth.
  • Perthsnob
    Thanks again Dave, I'll have a chat to the site sponsors. And thanks for the link below.
  • DaveD
    Maybe consider something like this:
    http://coffeesnobs.com.au/coffee-har...sh-sydney.html
  • DaveD
    Hi Perthsnob,
    That price is probably on the upper end of what I'd be willing to pay. A v2 silvia could be 7-10 years old, which is not a big deal if it's been well looked after. I do think Silvias are worth it as I have one myself. I would contact the site sponsors and see what they could suggest for your budget. Use the quote form at the top or bottom of the home page. If you're considering second hand I would look at the for sale section here in this site, as you'll be more likely to get a well looked after machine.
    Cheers, Dave
  • Perthsnob
    Originally posted by DaveD View Post
    Hi Perthsnob,
    Welcome to Coffee snobs! For the range of coffee preparation methods that you intend to use it for, I would suggest a stepped grinder. This will make it easier to switch between french press and espresso grind levels. This leaves you with the choice between the Macap M2M and the Rocky. I would go the Macap as I find the Rocky steps are a bit too big for fine tuning some beans for espresso. I also find the Rocky a very slow grinder. So I guess I would recommend the Macap.
    Cheers, Dave
    Hi Dave,
    Having decided to go for the Macap, I have just seen someone selling a secondhand Rocky and Silvia v2 for $600. Do you reckon that's a good deal? I don't want to hijack the thread, or go off on a tangent about coffee machines, but I will be looking to purchase a machine in the not too distant future - something affordable (<$1000?) that will let me learn and practice some barista skills, and then enable me to produce a commercial quality espresso. The Silvia seems to get mentioned a fair bit on here.
    Thanks.
  • Perthsnob
    Thanks Dave
  • DaveD
    Hi Perthsnob,
    Cheers, Dave
  • Perthsnob
    Hi guys,
    I am also looking at these three grinders, for use at home and to replace a really bad Bodum grinder. It will mainly be used for pourover, French press and aeropress, but also possibly espresso at some stage in the future.
    Edit: As this is for home use, I will be looking at something that doesn't take up too much bench space, and will ideally fit under my wall-mounted cabinets.
    And, what's the difference with a doser/ doserless machine. At this stage, I will be grinding low volumes, so presumably doserless will be best for me?
    Are all three as good as each other when it comes to filter coffee, or is there anything else that I should know?
    I am in Perth, are there any suppliers that I should go and speak to?
    Thanks.
    Originally posted by tonyh View Post
    I did use the quote form to contact all sponsors a couple of days ago, and I would like to thank the 3 businesses who got back to me.
    Good stuff Tony. We didn't reply as I figured freight would kill it for us and in all likelihood, you probably found us anyway.
    Good luck.
  • tonyh
