Hi
I have a Obel/ Bregent Junior grinder (also appears that it's known as a SAB Junior Coffee grinder). I need to buy the flat metal spring that locks the doser pawl gear as mine has broken can anyone direct me to where I can buy spares for this grinder? I downloaded an exploded drawing of this grinder but it does not show this flat spring steel part (don't know what it's called). I've attached a picture of the underside showing this part.
It's the flat metal spring steel anchored at the left, as you can see the tip has broken off.
Also I also just discovered that the dose level can be adjusted by an adjustment knob at the top. When I bought this I just plugged in & started using without knowing this. Can someone shed some light on how adjusting this knob adjusts the dose level?
Many thanks
Peter
Many thanks
Peter
