I just found this grinder (brand new) from one of China sourcing websites. It's being sold at $256 USD but there'll be freight/tax costs. Specifications:
Professional coffe grinder with aluminum body
Power supply: 220V-240V 50Hz / 60Hz
Technical Specification
Power: 350W Gross Weight: 15kg ü Weight: 15Kg
Dimension: Height 560mm / Width 210mm / Depth 330mm ü Assembled Height:
Bean Hopper capacity: 1.2kg. ü Assembled Width:
Grinding capacity: 6-9kg / hour ü Assembled Length:
Dispenser capacity: 250gr. (powder coffee) ü Grinding stones diameter: 64mm (flat type)
Dispensing capacity: 5-10gr / cup ü Bean Hopper capacity: 1.2Kg.
MOQ:50PCS ü Grinding capacity: 6-9Kg/hour
ü Dispenser capacity: 250gr. (powder coffee)
Knife diameter:64mm ü Dispensing capacity: 5-10gr/cup
Features: ü Electric Power: 350watt.
All Aluminum alloy casted dispenser, right/left hand handle.
Extra wide dosing capability from as low as 5gr to 10+gr per dose. Certifications:
Specially hardened tooling steel grindstones ü ETL.,CE,GS
Micro adjust table for accurate grinding ü NSF Sanitation listed
3 optional colors: Black, Red and Silver Packing information:
3 optional models: Carton Height:650mm
Manual (S): On-Off control Carton Width:280mm
Carton Length:390mm
Weight:15kg
The FOB price is about $256 usd but there'll be another 70-110 shipping (via boat - taking about 1 month). So it's actually about $356 + import tax.
Do you think it'll perform as good as the threshold standards like Mazzer SuperJolly, Caedo E6, Compak K6 ?
Actually, I plan to buy these 3 'Pre-owned' (Mazzer SuperJolly, Caedo E6, Compak K6) because I want 1 for hot coffee, 1 for ice coffee, and 1 for Decaf coffee.
Carton Length:390mm
Weight:15kg
