This problem is driving me nuts, so hopefully someone here can help!
A few weeks back, I decided to pull the top burr out of the Rocky to give it a clean, to which I am fairly confident I did everything to an acceptable level of gentleness. After putting it back together, I noticed I had to go from a previous 8 setting to 3 to get a similar flow rate in the machine (Silvia, if it helps).
But it was definitely more inconsistent than before, so I cleaned it out again and tried the common 'teflon tape' fix around the burr carrier. Now, when grinding, there seems to be a small amount of large particles (perhaps ~1-2%) interspersed with the fine grind (around 2 on the rocky). I wish I had a good enough camera to take a picture....The end result seems to be some gushing whilst making coffee.
Anyone had a similar experience or know what to do? I think as a last result, I'll order some replacement burrs.
