Rancilio Rocky grind level for espresso?
  • Rancilio Rocky grind level for espresso?
    greetings
    just curious - what grind level is best for espresso using Rocky grinder ?
    assuming burrs are in good condition and beans are fresh and are ground on demand.
    I tried level 7 and 6 and 5, not quite sure what is best, typically I use either 5 or 6.....
    thanks
    I am finding that I get best results (60ml double shot in ~25-30secs) on 2 or perhaps 1 if the beans are a little older. So I don't have much room to move. That's with about 17g of coffee, maybe I need to up the dose. It gets a bit clumpy on such fine grind settings.
    Rocky is a few years old, have cleaned and checked the burr zero calibration, so I don't appear to have much room to move. I haven't exactly punished it over the years, doubt that I would have put more than 20kg through it.
      it suggests that the grinder needs to be recalibrated to zero.
      This does require removing the bean container (three screws in the centre of the container) . If I remember correctly there is a self tapping screw that stops the adjustment just before the blades touching. It sounds like that your 2 should be around 5 or 6. If this is too vague I can pull my rocky down.
        G'day Acid rider,
        The numbers are just a reference point for when you move from different grind sizes. Your 'true zero' may be 9, or any other number depending on how the burrs have been assembled.
        Check this link that Mal put up in relation to zeroing in the Rocky.
        http://coffeesnobs.com.au/grinders/2...true-zero.html
          If you read my post, I did say I had recalibrated the burrs to zero, On the scale, the true zero is actually about -1 or -2, so I didn't try to shift the stop screw. My grind setting of 1 is still pretty low.
            mjs, yes I did read your post. I realised that I wrote the wrong info. I tried to delete the post but it would not delete!
            Even so 1 is still very close to zero. If the taste is good then great.
              Cleaned a friends ones and re calibrated it today. Looks good at about 5. Let's just say she got the hint when I said no to a coffee.
                Man that's one sad, neglected grinder. Lucky you were able to save it!
                  Phew, mine didn't look anything like that!!
                    Cheers. I will be dropping it off and will give her a quick lesson on how to regularly clean it.
                    put it all back together and adjusted grind. pulled a better shot than my mignon and bezzera do
                      Uuugh that looks like the wheel bearings from my '71 FJ40 Cruiser!
                        Was it grinding vegimite?
                          at least if it was vegemite I wouldnt have minded the smell
                            This post could quite easily go in an adjacent thread on what grinder to choose to replace a Rocky doserless with (Macap M4D is probably my preference), but this thread is talking about grind settings, so here is a bit of my experience this morning. Firstly equipment etc, Rocky Doserless, Expobar Minore III, jewellers scales, triple shot basket on naked portafilter, double shot basket in normal portafilter, Joe Frex digital timer. Beans from Industrial Coffee, Fitzroy St blend, bit over two weeks old. Strong latte is my coffee of choice, followed by long mac.
                            Firstly grinding at 2 using 20g, naked portafilter, firm tamp. The shot is ok, but got about 70ml espresso in 25sec
                            Then went to 22g, set at 2 on the Rocky, naked portafilter, firm tamp. Good shot, got about 60ml in 25sec
                            Finally went back to the double shot basket, 18g, ground at 1, firm tamp, got 60ml. This was the best of the three when made up. Pic of that shot to come
                              Here is the last pic of the 18g shot, ground at a setting of 1. Very good outcome in the glass when topped up with milk. Perhaps if the beans were dead set fresh, would have had a similar outcome at a grind setting of 2. Anything higher grind setting on my particular Rocky would not work for me.
