I removed the mesh entirely on my Super Jolly E and use an artists brush to sweep out chute resulting in zero retention, suitable for home but probably not for volume usage.
Mazzer Mini E - simple grid mod
In the Robur you can remove the filter by removing the doser cone with a couple of allen keys, and then the mesh is simply a springy laser cut metal sheet held in place by tension. Hold the mesh bits with pliers and carefully lever then flick out the sheet with a knife blade so you can reinstall later if you want.
But don't do what I did once - not use the pliers! It flicked out, then dropped into the hole in the grinder body. Had to disassemble half the grinder to find it and get it out again! You can't turn a Robur upside down and give it a good shake…
(maybe a few bits of tape and a sheet of paper over the hole is a good preventative measure)
On the ECM the grid is attached with two bolts; it's easily accessed on the V Titan through the top of the dosing funnel so I might try removing it and see what happens. I don't mind brushing the chute, this might be the perfect compromise between single dosing and timed grinder... or it might spray half a kilo of static-y grinds errywhere! 😂
Originally posted by Magic_Matt View PostI don't mind brushing the chute, this might be the perfect compromise between single dosing and timed grinder... or it might spray half a kilo of static-y grinds errywhere!
Originally posted by greenman View PostI use a small mesh scoop I bought from a kitchen supplier in the bottom of the cone to stop the static and clumping and just flick it with the brush when I clean the chute each dosing, it reduced the mess markedly.
I found this one before - might give it a try. It would still add some back-pressure, but easy to remove for cleaning… rather than screen / wires
https://www.kaffee-netz.de/threads/t...muehlen.60027/
Translated
https://translate.google.com/transla...ehlen.60027%2F
Here's the video…
https://www.youtube.com/watch?v=BY89...dsrDHQD_9qVYQ=
