Hi all
First time poster and newbie to the coffee making scene since I picked up a Breville Duo Temp half price at Dick Smith's closing down sale.
Been given an old Anfim Lusso on appro from a local cafe, probably way more than I need for a home setup but from what I have read it's a great unit if you can get it at the right price and in good nick.
This unit has seen some work and it's far from pristine, looked to never have been cleaned in its entire life; setting aside the doser and hopper I've spent something like 12 hours cleaning the grime and tar-like residue from the grinder itself (half a box of toothpicks just to clean the threads in the body where the upper burr carrier runs on). I washed and scrubbed in detergent the upper burr carrier and both burrs then dried them, removed the lower burr carrier and cleaned every inch of the grind chamber and exit with isopropyl alcohol to dissolve the oils.
Everything came up roses with the exception of that brass casting that holds the lower burr - it smelled a bit like hot engine oil when I first took it apart, and coffee ground with the machine comes out with a hint of this in the taste and aroma. I tried a few things to clean it but ultimately it needed steel wool and Jif to remove the dull coating of whatever was on it, although it looks like a sand cast with plenty of pits and imperfections where it has not been machined so likely I haven't got it all.
Everything *looks* fine and initially I thought I was good to go but I'm finding I still have a hint of that contamination coming through, and if I unscrew the upper burr carrier and run my fingers round the threads I can get a whiff of this oily smell come back again so I'm at a bit of a loss as to where I go from here. It smells like engine oil (sort of) and once it's on your fingers it takes the power of removing. Only seemed to be on the brass lower burr carrier and securing nut but I guess it gets spread around the grinder by the coffee.
What I've done so far:
Any ideas where to from here? Should I look to replace the burr carrier and nut? Is the grinder actually fixable? I'm stumped!
- Removed the hopper and doser (improvised a hopper and outlet chute for now)
- Cleaned the upper burr carrier, grind chamber, burrs
- Cleaned the burr carrier threads of accumulated crud
- Removed and scoured the brass lower burr carrier & nut clean after detergent and coffee machine cleaner failed to shift the film on it
- Replaced the dulled burrs with a new set
