In what almost looks like a completely different direction the team at Decent Coffee have released a grinder.
It has no doser, no timer, no fancy touchpad, no android tablet, just an off and on switch.
The interesting bit is the group handle holder has built in scales so you turn it on and then off when you reach the desired weight. Unfortunately no auto shut off when desired weight is reached
https://decentespresso.com/pro_grinder
Currently $1079Au plus shipping
64mm flat burrs. Made of food grade hardened tooling steel. Burrs manufactured in Italy by Italmill.
Grinding speed: from 1.5 to 4.0 grams/second.
Dimensions: 56cm x 21cm x 33cm.
Hopper capacity: 1.2kg.
Power consumption: 11A 350W.
Grinding capacity: 1000 drinks per day.
Discuss
Discuss
