Have had this grinder for about 18 months (so is out of warranty) and it has been a great grinder with no problems until now.
All of a sudden it has started clumping (worse than "normal") and has started choking. I can usually get it going by switching off at the wall which resets it.
I have tried cleaning it by removing the hopper and top burr and then tipping it upside down and getting in with a toothpick and brush to clear the accumulation of coffee grounds around the bottom burr, but it seems to clog up fairly quickly after doing this.
Is the problem the expeller wheel under the burr. Does anyone know if replacing this with a new one will fix it for another year or two? Clutching at straws, because I can't see how it can wear out, though.
Any other ideas or insight would be appreciated.
BTW, did do some searching but didn't turn up anything helpful this.
