The S64, T64, and V-titan 64 have essentially identical mechanics. The S64 has a portafilter rest not a holder, so you can't go hands free while it grinds, it also has a chute rather than the funnel the other two have. The T64 has buttons on the top of the grinder, whereas the other two have a portafilter button. The V-titan is a bit bigger than the other two. With these three grinders it really comes down to which of these features you want as they are essentially the same inside.
The Atom is quiet, like really quiet, for a grinder. Not silent by any means, but if most grinders are like someone with noisy vacuum right next to you, the Atom is like someone vacuuming in the next room with the door shut. You are definitely aware it's happening but it's not as overpowering. Also both the Atom and Zenith use a setup which means you won't have to dial the grind in again if you remove the top burr for cleaning, as it will be right where you left it. Most other grinders you have to wind through their settings until the top comes off, and then wind it back down again and hope you got it in the same place. The Zenith has an adjustable chute so you can aim it wherever you like (likely to make sure it is in the middle of your portafilter).
Atom 60mm burrs
S64, T64, V-titan 64mm burrs
Zenith 65mm burrs
Atom 60mm burrs
Zenith 65mm burrs
