mini mazzer advice please
  • Dr_Dave
    Re: mini mazzer advice please
    No thank you - Chris emailed his file to me
    Many thanks for the offer
    Dave
  • Wushoes
    Do you still require it? If you do, I can scan and create a pdf file from my manual....if I can find it!
  • mrnaive
    haha, Dr Dave, I felt the same too.
  • Dr_Dave
    Guys,
    Many thanks to you all, for your help - For someone who doesnt know many people in Australia I am humbled by all the help I have been offered. It feels like I am amongst friends. Thank you.
    Dave
  • gregpullman
    Yep I do, but its on my PC which is in transit to Adelaide! Luca sent it to me so check with him if youre desperate, otherwise email me later next week if I havent got it to you.
    Gday Dr.Dave,
    Couldnt find a Mazzer Manual for you, about the nearest thing I could find was an exploded diagram of a Mazzers innards here so I dont know if thats going to be much help to you or not. I guess if all else fails you could drop a line direct to the Mazzer factory in Italy and ask them to help you out.... Ive always found the factory personnel of most coffee machine manufacturers to be very helpful when ever Ive approached them for assistance, so could be one avenue to try, if you havent already that is?
    Originally posted by Dr Dave link=1183020328/0#8 date=1183207182
    pm sent back - thanks chris
    Also found it on Google however every time I click on it, an error message comes up and  Internet Exploer shuts down.
    Hence thats why I asked Coffee Snobs...
    Does  anyone  have it as a separate link rather than via wholelottalove?
    Must be your IE Dave. Have emailed a copy...
    2mcm
  • Dr_Dave
    PM sent...Google is your friend 8-)...Took me 2 minutes :P
  • Dr_Dave
    Thank you
    Does anyone have a link to a manual I can dnload please?
  • Wushoes
    and inconsequential if youre free dosing.
  • mrnaive
    Originally posted by Dr Dave link=1183020328/0#3 date=1183171275
    What is the bevelled nut and central screw for in the centre of the dispenser ? No manual with mine.
    WIll look on Google for a manula unless anyone has one?
    Thats for the amount of dosing for each click. Towards bottom=less dose,
    away from chamber=more dose.
  • Dr_Dave
    Many thanks for the advice - will try a "hard Thwack".
  • mrnaive
    The mazzer is a great grinder though does have its idiosyncrasies.  2mcm recommends that when dosing the PF, give the lever a good, hard thwack - this reduces the problem of throwing to one side.  I still tend to place my PF off centre and pretty much accustomed to it now and no longer have coffee spilling everywhere.  A large sized coffee matt to replace the dodgy plastic thing that comes with the mazzer is also a good option.
    Yep, when i first used the mini, i have the same problem too,
    just do it as quick as you can(seriously "hard thwack"), the problem can be fixed...
  • Dennis
    Hey there Dr Dave!
    As for the spray in the doser...I tend to find that this can be very dependent on variables like, grind, bean type and grind setting. Whilst a fine grind can fall out in clumps, if you are grinding something like monsoon malabar through the same setting it sprays all over the inside of the doser. Bottom line is that I dont think it much matters about the coffee dropping into different segments. Once you start thwacking it will pretty much clear this out anyway.
