I recently bought a new Macap M4 for my birthday. (Sponsor plug: Thanks Chris at Talk coffee for great advice and service)
I have had an Iberital challenge for 1 year but since I started drinking more decaf I was finding it a pain to constantly switch between beans in the mornings. I have been looking at the m4/mini/k3 trio and in the end it came down to the Macaps doser sweeping cleaner and being slightly quieter. After my first few coffees I thought I could taste a difference but I wasnt really sure. Today I pitted them in a grind off to make direct comparison:
1 cup each of PNG and Ethiopean Sidamo
Grinding
Both times the challenge was finished grinding quicker 23s vs 30s on the Sidamo and 30s vs 31s on the PNG. The shots were quicker on the challenge so the grind was slightly coarser. The biggest difference was volume. You can actually hold a conversation while the m4 is grinding, a pleasant change from the noisy iberital.
Changing grind is so easy on the m4 and you can quickly and accurately change grind settings for different beans. Having used the iberital for a year I am still getting used to the steps on the m4 but they are certainly not big enough to be an issue.
Dosing
The m4 has a longer and lighter dosing action which took a bit of getting used to. Both give slight clumping but the m4 clumps break up much easier so distribution is less work.
Shots
Both gave good looking shots with tiger striping and even extraction. The m4 was slower in both cases but that is most likely just a grind adjustment. Hard to separate the two grinder here. Crema on m4 seemed marginally redder.
Taste
The acid test (pun intended). I am no cupping expert so this is all very subjective. One thing I had noticed before and was evident today is that the shots out of the m4 have more sweetness. Both brought out the characteristics of each bean nicely. The m4 also scored better for aftertaste; it seemed to hang around a little bit longer.
Conclusion
I had high expectations for the m4 and I was not disappointed. I was suprised that it does not grind any quicker than the iberital. I wasnt sure if I was going to be able to taste the difference in the cup. The difference is marginal and my wife couldnt taste a difference between the two.
There is no doubt the m4 is the better grinder; At more than twice the price it should be! The fact that the iberital is so close is significant. Based on the more robust construction of the Macap I would expect it to last longer. Only time will tell how much longer.
So the winner is the MACAP M4! A round of applause please ;D
If your budget doesnt stretch that far then you can rest assured that the Iberital Challenge punches well above its price range and will not disappoint.
Regards
Gavin
Grinding
Dosing
Shots
Taste
Conclusion
Regards
Gavin
