First Time Buying Grinder - Need Some Advice
  • First Time Buying Grinder - Need Some Advice
    Hi Guys,
    I've been doing a bit of research on grinders and feel slightly overwhelmed with all the different options out there. I read Dimal's sticky about choosing a grinder for the first time however haven't been able to settle for a grinder. This grinder will go with a Profitec Pro 500 (yet to purchase) and I will be making espresso's 99% of the time so a grinder suited for this would be optimal. My budget is anywhere from $500-1000 (1000 is really stretching it).
    Any suggestions or advise is welcome.
    For general advice, get the best grinder you can afford. The grinder really is the key piece of equipment in the whole setup.
    Having said that, in the used hardware section here you can often find very well looked after grinders used only in a domestic setting. Often they are much cheaper than adverstised on gumtree/ebay as most of the members want to pass on their gear without fuss and see it go to a good home. Steer clear of the ex cafe grinders (unless they are in pretty good nick) as they often get a beating in the cafe and almost always the burrs need replacing.
    Personally, I bought a Mazzer Super Jolly from a fellow forum member and am still happy with the performance. I would love to go to a big conical soon, but it's more than adequate for my needs to date.
    Edit: There are two Super Jolly's, a Kony and a robour for sale in the hardware section at the moment. All very reasonably priced (the kony slightly over budget).
      That’s a relatively high end espresso machine and since you are mostly drinking straight shots you’ll really notice the nuances of a good grinder.
      You’re going to hate me saying this, but I’d lift your budget a touch to about $1200.
      This gets you into a class of grinder that you won’t ever need to upgrade. I’d suggest the Profitec T64 or the ECM equivalent.
      These are both fast, produce excellent quality grounds, and have accurate timed dosing.
      Odds are if you buy a $500 grinder you’ll find yourself wanting to upgrade quite soon, maybe within a year.
        Having been through a few grinder myself I can suggest a Eureka of some sort would fit the bill. Its only an opinion and the bottom line is whatever you get you want to be happy with. Trying to get your hands on something you like before you buy can help. There are many different names and varied prices for grinders. I feel what ever you do i would aim for something that doesn't clump. I went through a Breville smart grinder to a compak K3T to a macaap M4D and now to a Eureka Zenith. I have to say in hind sight had i known i wold have gone for the Eureka in the first place. The zenith is a little over the price range you said but they have some which come in under that also.
        Worth a look, but as i said i go for something that grinds a consistent grind without clumping.
        Also would you think secondhand? worth looking into
          Why not a Mazzer Mini Dave, within your price range, an excellent grinder, built like a tank and will do everything you need.
          The young Turks on the forum will have you believe that speed is everything and that the Mazzer range are antiquated monoliths, not so, I've owned a Mini for going on 10 years, it's never failed me.
          As far as the larger Mazzer grinders are concerned, they are big and heavy, not really suited to a home environment, although some do use them.
          Mini's show up quite regularly, secondhand, in the for sale area at reasonable prices, no need to spend over a thousand dollars to get a very capable grinder, bear in mind, bling adds absolutely nothing to whats in the cup.
          https://www.coffeeparts.com.au/machi...ctronic-silver
            Macap M4D or Eureka ATOM.
            Second hand M4D's can be had for as little as 400 bucks if you look hard enough.
            I've seen two ATOMs for less than 900 on here, however they're around the 1.1k mark new.
            You won't regret the purchase of either grinder and functionally they're far better than a Mazzer Mini or Super Jolly.
              Thanks for input guys however I should have mentioned I was looking for a grinder more suited for domestic use. Aside from the Eureka Atom and Mazzer mini the other grinders mentioned are quite large and wont fit in my kitchen. I've had a quick look at the Eureka Atom and the Rocket Fausto and from what I have seen these look well suited for my purpose.
              Can anyone list any pros and cons between the Atom and Fausto? Or any other quality grinders that aren't so big.
                The M4D is surely the same height or maybe slightly shorter than an ATOM?
                There's someone selling an almost new M4D in QLD on Gumtree for $550 - definitely consider this!
                  Agree, a rare opportunity...
                    If I was going again at that budget, the only one I'd buy is the Mahlkonig Vario. Mine's been a beast for about 5 years now. Almost no retention, great consistency, easy adjustment and I love the 3 timers on it (I use them all). It also takes very little counter space. The only downside for me is it's a little loud, and a little slow.
                      The S-64 / T64 both have a very compact footprint for fast 64mm grinders. Both outperform the Fausto in the same price range and footprint.
                        Thanks guys,
                        I have narrowed down my choices to the below.
                        -ECM S-64
                        -Eureka Atom
                        -Compak E5 OD
                        ECM S-64
                        I really like the look of the S-64 however had a look at reviews on a number of different forums and noticed that there were some mixed reviews (significant clumping, retention & gets hot), not sure if this was just down to a faulty device however has made me slightly hesitant.
                        Eureka Atom
                        Haven't found much negative feedback on Eureka Atom other than slight clumping, everything else looks to be positive. Only downside for me is aesthetics of the machine.
                        Compak E5 OD
                        Haven't been able to find much feedback\reviews on the machine other than a few youtube videos. Aesthetics look great however I don't want this to be the deciding factor, would much rather a good cup of coffee opposed to a nice looking grinder.
                        Does anyone have any experience with the Compak E5? Would love to know a bit more about this machine.
                        Any other feedback\thoughts is appreciated.
                          Grind by weight of the sette 270w is a good thing! Im grinding into the basket as its kind of unstable going straight into the pf- seems the vibrating handle upsets the weights. Also into filter means the grinds have enough room without backing up into the nozzle.
                          Around $600...and noisy. Good otherwise!
                            Between those I'd personally go the Compak. Build quality is probably a notch above those others. Londinium endorse these for their machines saying after extensive testing, they couldn't pick a significant difference to the E8. That's a fairly credible vote right there!
                              I am with Arcade's earlier post - for home use Mahlkonig (NOT Baratza) Vario (now up to gen3). Strictly a Turkish to espresso grinder unless you go for the $30ish steel burrs which then do coarser grinds (and no longer do espresso well).
                              I have 2 * gen2's (2013, done 200+kgs & 2014) and a gen3 (2016) - all flawless (Swiss made), compact, quiet, no retention worth stating, no static / clumping or any of the other ills which drive me spare these days. Too many friends have Roburs or other Mazzers with the most amazing arrays of wire grids, funnels etc to stop static / clumping - IMO something a decent grinder should never do in the first place.
