Function of Mazzer doser sector plate
  • kofekitt
    Adjusting the dose size - mainly for cafe use as most home barista will be single dosing, but if you remove it, stray grinds may come out of the doser whilst grinding . The plate holds them in the dosing chamber until you pull the doser lever
  • cinder
    Thanks. So really for cafe rather than home use? I always wondered what the plate up and down screw did!
  • kofekitt
    It has two purposes;
    - Stops the grinds falling out through the dosing hole when grinding
    - Sets the dose size as it is adjustable - The lower or higher the plate is, it sets the dose size
  • cinder
    started a topic Function of Mazzer doser sector plate
    This is probably a dumb question, but if I am just grinding through the doser, does this sector plate serve any useful purpose? It certainly makes the doser more difficult to clean.
