Name that Mazzer!
  • flewis88
    Originally posted by timmyjj21 View Post
    Pretty sure you can do all the usual Mazzer mods - instead of a massive bucket hopper at a ridiculous price, consider a Perspex tube hopper and a 58mm collapsible rubber lens hood (phot-R brand is good). Have a google for Mazzer mods, plenty of options to entertain you!
    Awesome! Didn't consider those [emoji16] sounds fun!
  • timmyjj21
  • flewis88
    It’s pretty easy to re-wire this beast to exclude the hopper safety interlock switch, a google search will pull up pics and wiring diagrams that are really simple to follow. Nice find BTW!
    Cheers mate! Yeah pretty stoked. Was giving it a good clean up today. I'm pretty comfortable with electronics, but I'd rather not modify it, I'll just make a bolt down tab to press it, so it can be taken out and a hopper used.
  • timmyjj21
  • flewis88
    Originally posted by chokkidog View Post
    Cut up your credit card and use that ..... best use of a CC there is. ;-)
    A true thinking man [emoji6] a yoghurtland spoon did the job for the first test!
  • chokkidog
    Originally posted by flewis88 View Post
    Fantastic thanks! Yep there's a safety switch which is activated by a tab on the hopper mount. I'll see what ingenious thing I can come up with to activate it safely.
  • WhatEverBeansNecessary
    Yes, you do lose some performance - but if it's just for a domestic setting then I wouldn't worry. The pressure from beans in the hopper makes the grind faster but an extra 10 seconds when you are only making 1 or 2 coffees really is nothing. 100 + an hour coffees at a busy cafe would be a pain.
  • flewis88
    Fantastic thanks! Yep there's a safety switch which is activated by a tab on the hopper mount. I'll see what ingenious thing I can come up with to activate it safely. There's no lack of performance from 1 dose only in the grinder? I heard a mate say years ago that he always put more than necessary in the hopper to push the beans down in to the burrs. I suppose it might take a tiny bit longer, as they bounce around, but the burrs clearance is still fixed.
    Cheers! As in, bypass the hopper safety switch, and modify some sort of container to serve the same purpose as the hopper?
    I don't know if there is a safety switch on the Major/auto models of Mazzers. But more generally weight out my exact dose 16.2g and then tip that into the throat of the burrs and then place a basket over the top so beans don't go flying when they grind - probably less so for conicals than flat burr grinders like the Super Jolly.
    You can see sitting directly on top of the grinder where the hopper would normally sit is a small plastic container. I take that off - dose my beans into that on the scale and tip the beans into the grinder, then replace the plastic container and grind away.
  • flewis88
    You will be able to get a hopper brand new from CafeSpares. But it won't be as cheap as a second hand one.
    For what it is worth, I prefer single dosing into my super jolly - just weigh out exactly what you need and then dose straight into the burr assembly. I use a small plastic container to stop wayward beans flying out everywhere but I have seen people also use spare baskets.
  • flewis88
    Awesome, thanks all for the help! Knew I'd seen 2 of them in my local cafe, but never knew what model it was.
    Any idea where I'm likely to pick up a hopper assembly? I'd be so happy with a second hand one.
  • Koffee_Kosmo
    That is definitely a Mazzer Robur
    And a newer model with that auger on the lower burr ( this helps feed the beans to be ground by the burrs )
  • LeroyC
    Robur for sure.
  • flewis88
    I'd not seen flats before. Interesting.
    Found this in council cleanup! Pressed the hopper safety switch and the motor runs. Beauty! Now to find a hopper.
