White grinder to pair with LM Linea Mini
  • White grinder to pair with LM Linea Mini
    I am in a process of purchasing a LM Linea Mini, contemplating whether I should go with the LM LUX D as a pair or another brand's grinder in white.
    Any suggestion for a capable grinder in white color and relatively smaller siE to fit in a small kitchen?
    Eureka Atom
    https://www.jetblackespresso.com.au/shop/p/eureka-atom
    https://www.coffeeparts.com.au/eurek...coffee-grinder
    https://dibartoli.com.au/eureka-atom/
    Compak E5OD
    https://www.jetblackespresso.com.au/.../compak-e5-od/
    I believe the LUX is a rebadged Mazzer without a timer, you just hold the portafilter button down.
      Is the LUX a manual grinder? Meaning I'll need to weigh the ground every time to get 18g?
      Originally posted by level3ninja View Post
        Yes it just had a button you hold down to grind and let go to stop. From the LM website:
        Whether you use a scale to weigh your dose or fill and sweep the excess, the Lux delivers coffee simply with the portafilter button
          Another option could be one of the new Eureka Mignon's... improvement on the older model Mignon, smaller than the Atom, can get them with timed grind.
            Quamar Q50 comes in White and there are push or electronic versions of it around.
            Very compact grinder and it is quicker than a Mazzer Mini, I had one for 6 months or so (come to think of it wish I still did now I have a better machine :-))
            Very well built and super compact.
            Just checked and this is not stepless so I don't think it is going get the best coffee out of a Linea. Also a couple of threads on here about Q50s having issues.
            Last edited by roosterben; 13 September 2018, 02:21 PM. Reason: Added comments about stepless
              Niche Zero comes in white.
                ek43s in white XD
                Found an image on the internet, you can replace the tall hopper with something short to fit in the kitchen
                  You can get the Mythos One in white too.......
                  Or just get what suits and do a custom paint/powdercoat job on it.
                  We do so many custom machine finishes now I have almost forgotten what a 'standard' machine looks like!
                    As you can see there are a few options and budget will have a big say. the size of the grinder compared to the machine might as well. The only other thought I had was that if you get a different branded white grinder the ‘whiteness’ and texture might be different, and not as matching as you may hope.
                      Originally posted by sharkroman View Post
                      ek43s in white XD
                      OMG that is an amazing home grinder !
                        I have personally settled on the White Atom to pair with the LM. Seems like the obvious choice!
