Quiet home grinder - Eureka Silenzio or...
  • #16
    Originally posted by level3ninja View Post
    What machine do you have? Do you have any plans to upgrade it (and I assume you won't want to upgrade the grinder again too)?
    Sunbeam EM6910 (yes, I am aware). Yes, it will be upgraded too, one day, and I won't want to upgrade the grinder again at that point.
    • #17
      Aware of what?
      Is the drip tray full indicator a circle or a line? You might be surprised how good a shot you can get from it with a good grinder and VST basket with matched tamper. If you're willing to single dose of suggest the Niche Zero as a quiet grinder.
      • #18
        Aware of what?
        Aware that it's significantly cheaper and noisier than the grinders I'm considering. Indicator is a line. Not really up for single dosing.
        • #19
          I've had sensational coffee made on an EM6910 so I agree with aiming for a good grinder as a priority. It sounds like your grinder needs are a bit more than just 'quiet'. Lots of variables to consider:
          Price
          Grind quality
          Space (eg how tall)
          Burr type (flat or conical)
          Doser or doserless (overwhelming preference is for doserless these days)
          Stepped or stepless adjustment
          Ease of use (eg programmable or manual control)
          Grind retention
          Speed
          Parts availabilty (eg replacement burrs)
          Make a short list based on your own research and check out grinder buying guides. I recommend visiting a site sponsor or other vendor who sells a wide range of grinders.
          • #20
            G'day EdwardC
            I come from a long term (1970... getting old...am old...) background in commercial espresso machines and grinders. Most of them are not very suitable for home use and almost every espresso machine I used before 2000 is now technically inferior "in the cuppa" to any reasonable machine (like your 6910) these days. Reliability is directly related to maintenance, and almost every espresso machine (and grinder for that matter) needs lots of TLC to go the distance. Yesterday I finally bit the bullet about some of that as a number of more expensive newer machines are also inferior today - some by a huge margin. See https://coffeesnobs.com.au/brewing-e...tml#post646493.
            Over to grinders.
            I am at 2 locations, so everything is in pairs. FWIW, my new 480s were calibrated and had the eccentricity and dynamic play set to a minimum at a mate's "medical stainless" engineering workshop - one needed a fair tweak, the other one almost nothing, which shows how 480s can vary from one to another "out of the box". I reckon my 2 were about as good as any 480 can get - and they served me well for quite a few years. I upgraded from 2 EM480s to a new, Swiss made, Mahlkoenig Vario gen2 in Nov 2013, then a second new Vario a few weeks later as it was so impressive.
            The Vario is a lot quieter (NOT silent by any stretch) however it was the superb Turkish to espresso performance in terms of particle spread that was a large step up. The Vario being compact, having very low grind retention (important for a mere 2 coffee sessions per day of 1 to 4 coffees each), no clumping, static or any of the other multiple PITA aberrations that plague a number of commercial grinders were a bonus. No mess on the bench / floor by throwing grinds everywhere was nothing short of a godsend at one location where the grinder is right at the front of the bench (domestic harmony rules).
            My own two Varios were joined by a "too good a bargain to avoid" new gen3 in January 2016. I was swayed due to constant posts on HB and CS about the unreliability of Baratza Varios so I bought a "spare in advance". Ironically, about a fortnight later one of my friends cafes had (yet another dead burr) issue with his commercial SJ grinder and I took my oldest Vario there as a stopgap "for two or three days". Just over 6 weeks later his new burrs arrived, and the little "domestic appliance" (according to some traditional coffee aficionados) Vario had managed over 40Kgs a week for all that time without breaking a sweat. Apart from need to clean the chamber out every three or four hours my mate was sorry to see it go - it massively outperformed his big beastie "in the cuppa" as well as giving him more bench space and less noise. When it finally returned home I checked the Vario's reputed "long life ceramic burrs" against the other two Varios with a microscope - no noticeable wear. The same grinder has now done two more shorter stints at that site until my friend finally cracked and bought an EK43 for his cafe. So after well over 250Kgs my first Vario is still as good as the two newer ones, which has put the reliability question to bed AFAIAC. Since then I have "repaired without parts" a few other Varios from friends, rellies and a couple of like minded CS'r's - none of them would have "failed" without poor cleanliness or lack of maintenance and only one of them took more than 15 minutes to sort - it had a butchered repair done under warranty (just like my first 6910 - another sad story).
            So my take - if you only do espressos, consider the Mahlkoenig (not Baratza - it is a grey import) Vario gen3. Not perfect, however if you have a good 480 - as seems likely because you have been happy with it for a while - there is little point in moving sideways rather than upwards.
            TampIt
            PS I "upgraded" one 6910 to a 7000. Although a lot quieter (domestic harmony still rules there) it is not as good "in the cuppa" or at frothing milk as its predecessor. Not an upgrade in my view. I have now bitten the bullet and have a Decent DE1Pro - it is a big step up in terms of flexibility (and cost...), however I have not had it for long enough to comment beyond first (very favourable) impressions.
            • #21
              Thanks TampIt, I'll check out the Vario.
