I have done a easy mod to my lido E. It makes adjustments easier to track and more repeatable. It just involves some adhesive tape measure.
So, I have the mm scale adhered to the lock ring, and a indicator attached to the body. Also there is a indicator attached to the bottom burr carrier (base).
In my use to adjust, I hold the lock ring and the body, loosen the base. Then adjust the lockring slightly according to the scale, and then hold the lockring and the body at its setting and tighten the base to its alignment mark. This ensures there was a adjustment, and the base/lockring is at same tension every time.
Yes, 1mm movement does make a very small difference to shot time/weight.
