Macap M2D timer q
  • Macap M2D timer q
    Gday,
    Does anyone know if the newer M2D with the front timer switch has an ‘override’ function? As in depress the switch and the dose is not timed
    cheers
    Not that I have managed to find. Also, if you want a double, you're looking at 2 grind operations.
      Thanks for the reply. I ended up going with the M2M!
