Macap M2M - Stepless upgrade kit?
  • Macap M2M - Stepless upgrade kit?
    Now that the M2M is a stepless grinder with the worm adjustment - is is possible to buy these parts loose and fit it to the older M2M stepped model?
    The M2M stepped grinder is not bad on the whole, but my main issue with it is just the step sizes and converting it to stepless would be great!
    Technically possible, but you'd need the worm drive and then have to drill three holes in the grinder body to mount it. The grind setting pin needs to be removed as well. I think that the upper burr carrier you have will work.
