purchase advice Ceado E37S
  • #16
    It would be very convenient for all the many different lands that use 240v but have different plug types I guess. Shame they don’t do that, it would be great.
    • #17
      Ended up purchasing a Eureka Atom 75, arrived today so will have a play when i get home tonight.
      • #18
        May I ask whom you purchased the Eureka Atom 75 from?
        • #19
          Just in case anyone was wondering. I have a e37s. Big flat burrs that are easy to clean and replace. Taste in cup is great imo.
          Pros:
          - Fast will grind up 21g in 5-6 seconds
          - great build quality, damn heavy
          - can use the mini mazzer hopper the one it comes with is huge
          - not much clumping and grinds are soft - best compared to M4D/Vario
          Cons:
          - the chute can get clogged, it goes through a metal part and then some anti static rubber. The thin aluminium part can get clogged when grinding alot at once.
          - LCD screen is too dull, if there's any direct sunlight it's pretty hard to see
          - retention not fantastic, as a result of the double chute design (the Mahlkonig vario had little retention)
