Baratza Sette 270 Gear Drive replacement instructions
  • Baratza Sette 270 Gear Drive replacement instructions
    I'm in the process of installing a new gear drive/outer burr assembly on my Sette 270W as part of the upgrade process to 270Wi. I have removed the old drive OK but before replacing it just want to check if I've missed anything. There is a pdf instruction guide (Sette-Gearbox-Assembly-S913-Replacement.pdf)that's supposed to be available on the baratza website, but its chucking a file not found error message.
    Does anyone have a copy of this file they could send me to complete the job. I've got bits all over the kitchen bench i need to have done with by dinner!
    I don't have a copy of the file, but hopefully this vid might help?
    https://youtu.be/Wflgc4dqm6o
      Many thanks for the link. I had been watching that video, but it only covered the combined motor and gear drive replacement, whereas I needed to separate those two parts and that was what I was having concerns with. I had it more or les worked out, but I don't have spare grinders to practice with and didn't want to stuff it up.
      However, last night, Five Senses Coffee (the distributor of the Sette) were able to provide me with a copy of the pdf gear drive replacement procedure. I have always found them very helpful with support and warranty issues.
        Might I suggest uploading the file to the Grinder's Documentation area so others can easily access it.
        Java "Data! Must have more data!" phile
        Toys! I must have new toys!!!
          Hope this helps.
Name:	Data Star Trek.jpg
Name:	Data Star Trek b.jpg
            Java "How did I see that coming?!" phile
              phile
              Done and added a couple more for the Sette
                The future tinkerers of the world thank you!
                Java "Tinkerers unite!" phile
