Help needed - 20 years of grinds in La Cimbali MD6
  • #16
    Originally posted by Dimal View Post
    Welcome mate...
    Pretty sure you can get them for a lot less than $600...
    https://coffeesnobs.com.au/grinders/...mbali-md6.html
    As per above...
    • #17
      Originally posted by herzog View Post
      Just putting it out there, but I’m not sure plowing good money into this machine is a great idea. Based on your description, it sounds pretty clapped out.
      Unless you’re wedded to the idea of doing it as a restoration project, throwing 600 bucks at it would probably be throwing good money after bad.
      That money would go a long way towards a quality new or lightly used grinder that will give you many years of service.
      Agree with herzog as there are probably a lot of companies out there, like ourselves, who rebuild grinders and sell them reconditioned with new blades too Cimbali has always had a bit of a reputation for costly and difficult to source parts. If you would like to contact us with a picture of your grinder, I could check if any of our blades are interchangeable and cheaper for you?
      • #18
        I don't believe the machine is "clapped out". Just dirty from 10+ years without a clean. The motor runs fine. All parts are intact except the broken tamper (I can live with that). The burrs maybe could do with replacement. When I purchased it I googled cimbali burrs and saw posts talking about $100-150. I paid $115 for the machine so am happy to spend $150 for new burrs, not $600.
        • #19
          Originally posted by Javaphile View Post
          Or he's not going about it in the right way.
          Java "Picture what?" phile
          No, I was going about it the right way. I now have access to computer file as well as URL. Maybe I was too quick to try and upload a picture after getting 5 posts.
          • #20
            OK Previous post shows picture of the black ball on top of the shaft (was going to say black knob but it just didn't feel right!). The machine seems identical to other MD6 posts except for this. How do I remove the ball the access the nut holding the burr holder to the shaft?
            Will post an image of the whole machine this weekend.
            • #21
              The pupae of the critters living under the stationary burr.
              • #22
                The actual critters (Insecta coffeegrindus)
                • #23
                  I can nearly smell that grinder from here
                  • #24
                    Originally posted by ekrabappel View Post
                    [ATTACH=CONFIG]22812[/ATTACH]
                    Oh yuk...
                    At least it can be cleaned up.
                    • #25
                      Oh yuk...
                      Or repurposed as a boat mooring.
                      • #26
                        I don't see the pics in posts 21 and 22, comes up with message "Invalid Attachment specified"
                        • #27
                          Ditto.
                          Java "Delete and re-attach" phile
                          Toys! I must have new toys!!!
                          • #28
                            Not sure I want to see
                            • #29
                              File was 3.3MB so maybe it got rejected? Odd that it was showing for a while. Have resized.Click image for larger version
                              Not as clear though. Back to my original post, any ideas on how to remove the black ball from the shaft?
                              • #30
                                I would try a spanner on the nut and some rubber or something grippy on the ball with your hand
