Help needed - 20 years of grinds in La Cimbali MD6
  • #31
    Remembering it's likely a reverse thread.
    Java "Both the nut and the ball" phile
    Toys! I must have new toys!!!
    • #32
      Having another look in the shadow under the ball appears to be a square section. Is that part of the same piece as the nut or could you put a second spanner on that and separate them?
      • #33
        I think the square section is part of the shaft. Surely the ball will pull off or unthread by hand.
        • #34
          Originally posted by level3ninja View Post
          I would try a spanner on the nut and some rubber or something grippy on the ball with your hand
          Trouble is the ball is just below the rim so hard to get a grip on it. On the previous MD6 thread I wonder if the square section came off with the nut?
          • #35
            It is hard to get any spanners on to them as they are sitting at the bottom the the well. That is why I suspect the ball must come off so a socket can go over the hex nut. But whether the ball and square section are permanently joined or whether the ball screws onto a thread arising from the square section, I have no idea.
            • #36
              Not to date. It needs some leverage as it has been 10 or even 20 years since it was last removed. Trouble is, once I apply leverage, I may break it if trying to unscrew the wrong piece.
              • #37
                Ah yes, that thought has crossed my mind. Another reason for my reluctance to apply leverage without knowing which way to turn it.
                • #38
                  Per its parts diagram it appears to be a separate part.
                  Java "RTM to the rescue again" phile
                  • #39
                    Update - finally remembered I had a pair of tongue and groove piers with leather glued over the business end. Carefully tried lefty loosie but seemed to shift a fraction and stiffen so I tried reverse thread undo and it worked. Surprisingly the ball seems permanently fixed to the shaft (unlike as shown on the parts diagram) and the shaft with the square sides at the bottom actually screws onto the motor shaft. Even more surprisingly, the hex nut that I thought would be the primary nut for holding the burr bracket on the motor shaft is just a spacer and has no thread.
                    Have now removed the bottom plastic casing and noticed the critters have been dropping pupae and their own dead bodies all over the internal electrics (plus a few cockroach eggs to boost) so I won't sleep well until I have torn it down and cleaned it well. Will tackle some more this weekend.
                    • #40
                      Reality wins!
                      Java "" phile
                      • #41
                        That would be living out in the garage..
                        Might scrub up ok though. Good on you for having a go
