EM0480 Coarse grid after cleaning
  • EM0480 Coarse grid after cleaning
    I have a EM0480 grinder thats about 18 months old. Only grind 2-3 double shots a day.
    This morning, even though it was grinding just fine for my EM7000, I thought I should give it a clean.
    Cleaned as per manual, reassembled, and not the finest grind in super coarse.
    Tried numerous times dis/re/assembly
    What have I done wrong?
    Have you checked the nut holding the bottom bur
    I had a similar situation only it went finer , and i believe mine was not assembled properly from the factory.
      Thanks Ross, the nut turns when I try to tighten it. How do I 'lock' it so i can tighten?
        If its loose take the nut of and remove the bur and clean everything carfull not to loose washers ect , you can see where the shims go for future reference, to tighten the nut i have plyers with soft covered handles that i jam up aginst the burs and tighten up, just a nip is good , rememer the threat is opersert. Hope that make sense
          I think I it sorted. Not in the f manual
          The top burr is threaded - and screws into the bottom of the grind adjustment ring.
          After a bit of trial and error I had the top burr screwed into the adjustment ring before I put it back onto the grinder.
          Tried a few test grinds and seems okay!
