Hello, I write because I'm desperate with my Eureka Atom, I've had it for almost a year and I have almost half of the time with blocking problems because of the known problem these models suffer in the tube where the coffee comes down. I recently installed the upgrade to supposedly solve this problem but it didn't work.
After installing it, I checked that after the first coffee that I grind, has already blocked, I have not ground excessively thin, because I would like to grind finer still but I find it impossible because it tends to block more. Right now I am desperate, I do not know if talking to the brand I would repair if it has a solution, I see it difficult right now.
Someone had problems with the upgrade and could solve it? any advice to try to fix it?
Thank you!
Thank you!
