Rocket Fausto wont grind as if its blocked
  • Rocket Fausto wont grind as if its blocked
    Hi everyone. My Rocket Fausto atleast twice a week seems to get blocked where the burrs are as if there is something stuck in it like a hard bean. This is painful because i have to dial my grinder out to a really course setting and then redial it back in to an espresso grind wasting beans. I checked the burrs and they are perfect and just got coffee machine serviced by cafe service here in adelaide and they had a look at grinder aswell.
    Any ideas. Is this happening to other people?
    Michael
    Are you adjusting the grinder while the motor is running? Adjusting while the motor is switched off can cause jams.
      My Fausto sometimes has a dry run when the beans in the hopper are getting low. All I do is use the single dose button which is set to 2.5 sec. this seems to clear the chute. I have also just stirred the beans up which seems to work. I haven’t had this happen since I cleaned the grinder.
