This grinder is available in the US.
Features are:
The power cord comes from the bottom, not from the side.
Grind time is displayed in 1/10 of a second intervals. To achieve your desired amount dose once, measure the dispensed amount; divide the amount dispensed by the time on the display. Now divide the desired amount by the results and that will tell you what to set the time for to achieve your desired amount.
Example: The display for the double reads 6.0. You measure your dispensed amount; its equal to 14 grams. Divide 14 grams by 6.0 seconds and your results are 2.333. That tells you your grinder dispenses 2.333 grams of coffee per second. You want 17 grams? Then simply divide 17 grams by 2.333 and the results tell you to set the time on the digital display to 7.3 seconds.
Sounds good? Now the bad part.....US introductory pricing is Mazzer mini-e territory- read maybe as much as $1200. Would you want one if we could get them?
Features are:
