question about rocky doser grinder
  • smoky
    Re: question about rocky doser grinder
    Originally posted by davem link=1196301433/0#0 date=1196301433
    Hi im new to cs
    been a bit of a lurker as there is a wealth of info here
    i wonder if one of you coffee gurus could answer the following for a noob with a rocky
    i cant seem to get a fine enough grind on it for my - also new - silvia.
    ive read about finding the correct "zero point"on the grinder and at zero on the counter the grinders are touching just - i think as it makes no noise at 2 tiny noise at 1 and a bit more at 0.
    i worked my way back from about 6 as recommended in the manual but even at zero i have to updose a lot to get a proper shot in 25secs
    it tastes ok....
    ive noticed some ppl say there zero point is negative?
    i wondered how this is possible as i cant make the counter go into the negative?
    im a bit worried about doing that anyway as i get a little grinder noise at zero ...
    but even my old delonghi burr grinder - dont laugh - gets a finer grind at 3 than rocky does at 0
    thanks for helping a poor noob get his daily coffee hit again! (hate leaving the house to get a coffee without already having one under my belt!)
    cheers
    dave
    Hey, I wouldnt knock the Delonghi grinder, Im using one, have been now since starting out 2 years ago and its always given me a grind that has the right consistency and damn nice coffee. After all, isnt it the taste of the coffee that is the effect we are all after.
    Ill think about a new machine, if I ever find the money to spend, as my Sunbeam is starting to get a of a burden on the upkeep side, (used and used and abused, not surprised). But, if I ever get the money to waste, then may consider looking at another grinder if I find one that isnt too much for what you want in the end result...
  • davem
    thank you Chris
    this mini service worked a treat!
  • davem
    Originally posted by 2muchcoffeeman link=1196301433/0#3 date=1196309027
    Ok Matt and Dave- the Abridged version is:
    With the grinder switched off and unplugged
    [*]Unscrew the 3 screws in the hopper and remove the hopper[*]Undo the brass top burr holder- and clean it, the balce and the lower blade thoroughly (I use a coarse grinder brush to do this)[*]Reassemble and tighten until the top an bottom burrs are in contact- i.e you cant tighten any further and then back off the grind by 1/4 turn. This will be approximately the correct grind for espresso[*]Reassemble the hopper assembly- if you orient the hopper correctly, your now ballpark espresso grind should read 10 on the scale on the hopper.[*]Enjoy your newly mini-serviced grinder....
    ahhh thank you Chris
    you are a champ im off too check out my rocky with a screwdriver - in a good way
    dave
  • mbg963
    Originally posted by 2muchcoffeeman link=1196301433/0#1 date=1196302527
    Hi Dave,
    It will be an easy fix.....
    Rather than writing a thesis, Im happy to talk you through it if youd like to give me a buzz...
    Chris,
    I might have the same problem - grind not fine enough at a very low setting - is there an abridged version of the thesis?
    Matt
    Hi Dave,
  • davem
    started a topic question about rocky doser grinder
    Hi im new to cs
    it tastes ok....
    cheers
    dave
