Modified Breville Cafe Roma
  • marcstolk
    Re: Modified Breville Cafe Roma
    Originally posted by jcl link=1196673829/0#0 date=1196673829
    till you achieve the perfect grind.... ;D
    No such thing as a perfect grind on this unit Im afraid. No matter what you do.
  • Burlof
    Yes, but they also made a grinder called the Cafe Roma too.
    Just to confuse us all ;-)
    http://www.breville.com.au/products_detail.asp?prod=205
  • Secksy
    Isnt Breville Cafe Roma an espresso machine?
    Andrew
  • jcl
    started a topic Modified Breville Cafe Roma
    I bought a cafe roma several weeks ago as it was all i could afford, when i started using it I soon discovered that I couldnt get a fine enough grind from it. The shop I bought it from wouldnt take it back so i made some mods and now it gives my a fine grind. The following mods make it better.
    Remove the burr grinding wheel and take out the three screws that are on the underneath.  Use an old credit card or something similar in thickness and strenght and cut out three small squares.  Place these squares between the burr and the burr housing then reassemble.
    Once you have done this put the machine back together and start grinding putting it on the max setting and work your way down till you achieve the perfect grind.... ;D
