conical vs flat
  • #16
    Re: conical vs flat
    Originally posted by YeeZa link=1210487170/0#14 date=1210556612
    Trust me David, I know where to get one and I know how much they are.... thats not my problem if you know what I mean. Its the justifying part  ;D One day..... :
    You will find that once you have one, its easy to justify! 8-)
    • #17
      Re: conical vs flat
      Yeah Ive worn that excuse out already for this year haha ;D Ill be digging into my 2009 quota of that excuse if I got one.
      • #18
        Re: conical vs flat
        Originally posted by Gavin1 link=1210487170/0#13 date=1210556255
        hmm....the metal forks vibrate too much on the k10. when I rest my PF on it, it rattles like a &^#$.....
        I have no such issue.
        You should see what the Elektra grinder does to a La Marzocco portafilter! Its like a JACKHAMMERRRR [smiley=angry.gif]
        • #19
          Re: conical vs flat
          oh reaaally?
          Might be different forks?
          Mine just goes nuts when the PF spout touches the fork. BRRRRRRRRRRRRRRRRRRR
          Hmm....might be some tuning forks they found lying around!
          • #20
            Re: conical vs flat
            Originally posted by cremakid link=1210487170/0#11 date=1210539811
            The 60mm flat burrs of the Cunill range are not what one would call cheapies, they are top quality and will grind consistently and last as long as many other "non-cheapies". So starting with the Tranquilo at around $395 there is no need to spend $600 if the burrs are the main issue. IMHO.
            If this grinder was a little smaller I would have got one instead of the Challenge
            Got to have the space on the bench
            • #21
              Re: conical vs flat
              Gotta say with the Challenge youll not be getting the most out of the Galatea - Ive tried it with the Challenge, the KS and the Macap M4, and I can tell the difference blindfold Im sure
              • #22
                Re: conical vs flat
                ....and a whole new world awaits up in K10/Robur conical land
                • #23
                  Re: conical vs flat
                  Amen to that!
                  • #24
                    Re: conical vs flat
                    I have a triangle of bench space available
                    Side 40cm X front 40cm X back 30 cm B/4 it falls off the bench
                    Hight is not much of an issue but the wife factor may come into it as it did when she chose the Bezzera Domus
                    So would prefer a low profile grinder if possible and pre loved to keep costs down
                    Chris recomended the K3 when I asked him a few weeks ago
                    The Mazzer Robur is 28 kg empty and about $3000
                    Im afraid would not get enough use at home
                    • #25
                      Re: conical vs flat
                      Originally posted by Koffee Kosmo link=1210487170/15#23 date=1210640820
                      So would prefer a low profile grinder if possible and pre loved to keep costs down....
                      Hi KK,
                      It might be worth making a WTB post in the Hardware for sale thread? There are a couple of mazzer minis there as well...
                      • #26
                        Re: conical vs flat
                        A robur is a just a monster.
                        at 500RPM and 71mm blades the thing just hacks away at the beans you put through it at home.
                        You turn it on for 3 seconds and ur done....
                        • #27
                          Re: conical vs flat
                          Ok Ok this is wife sanctioned by the way
                          I have placed an order with Chris on the Macap M4d electronic
                          • #28
                            Re: conical vs flat
                            Its actually closer to 4 and 4.5 seconds....not that 1 seconds makes a difference at home
